external drawings?
hi,
ok, i have 3 different houses on separate archiad files. for example a.pln, b.pln and c pln.
i need to put those three houses side by side in arched file "all.pln". It should look like one big house.
it would be possible to copy them and so on, but, i would prefer, that if i'll make some changes in file a.pln, those changes would be mad automatically in all.pln file.
is it possible to make this thing with linking to external drawings? i've tried, but not sicced.... any explanation guys?
Check "Hotlinked Modules" in the Help file and it will give you the solution to your question.
