finishes aren't turning in section?
Can someone explain why the finishes aren't
turning into the opening in section like they do in plan?
See screenshots below, I put the plan view in this post and the section in the next.
Seems like everytime I turn around it's something else...Ugh, never ending Ugh.
Been trying not to think about having 24 building sections that don't show the top plates and sill plates.
Thanks
3 Replies 3
Here is the section view of the window above
See:
http://archicad-talk.graphisoft.com/viewtopic.php?t=44615
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Karl,
Okay, it's a glitch.
I had tried the show in 3d radio button too, results were ridiculous.
I also noticed the other problem you mentioned and it's why my morph foam window surrounds are up a few stories and shown in plan in 2d line work...ugh.
The plaster/stucco edge in plan as it turns into the frame is not in the correct position / location. Guess I'll have to let this one go until graphisoft fixes this.
GRAPHISOFT!!
