foundation walls in hotlinks
Hello Archicad users,
i'm linking multistory attached garages into other projects.
The garage hotlink contains foundation, main floor and roof story.
Main floor and roof level settings are always identical with the settings of the projects i link into. The only issues are the basements/ foundation levels/ stories:
The Garage foundation extends 5ft into the ground - the regular basement level is either 8'-5" or 9'-0".
The result after linking the whole Garage at once is a incorrect position for the garage foundation in the combined project.
Reason is the reference line of the foundation wall at wall bottom and tight to the foundation story's origin. is there any possibility to have the wall reference set to the top of wall?
I appreciate your help! Thanks a lot.
0 REPLIES 0
