Gus
grid lines show up in 3d view. How can I get others to show
Grid lines show up in the 3d view on the "grid plane" below the model. How can I get other objects to show up on that plane? For example I turned some text into an object then placed it so it would show up on every floor plan. How can I get this "text object" show up in 3d next to the grid lines on the "grid plane?"
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W [email protected]
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
Eduardo Rolon
You will need to use the 3D Text Object instead of regular text. For other lines use the Morph tool to draw them.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Dontknow
In your 3D view you can only see 3D objects.
If you want to create text in your 3D view you'll have to use 3D text.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
