help. problem with file . . .
I lost my plan, i have 3d and sections but plan is missing. This is long object, more that 350 meters (power plant project) and i have to draw more, a lot of ...
i have some creazy digits
look at pic
3d and sections works but i dont have nothing on plan, tryed to restart archicad but even when i open this file i get this . . .
i will try at home, maybe reinstall archicad ? what do u think ?
i fixed this by merging this file into new file and it works now . . .
Its good you found a solution. Probably was just drawn too far away from the origin. Did you try a zoom extents and select all?
