2023-05-02 03:13 PM
Is it possible to hide wall endings seperatly from walls in Archicad 25?
I see it is not possible to move only wall endings to another layer as well it is not possible to filter them out at "View_Elements in 3D view " option
I would like to show wall endings separate from walls.
Anyone has an idea how to achieve it?
Solved! Go to Solution.
2023-05-04 12:33 PM
Hi Ananas,
Wall ends are hosted elements, you can't hide them separately. Unfortunately neither can be filtered out in 3D. You can use pillars with complex profiles instead.
David
2023-05-04 12:33 PM
Hi Ananas,
David
