ananas
hide wall endings
Is it possible to hide wall endings seperatly from walls in Archicad 25?
I see it is not possible to move only wall endings to another layer as well it is not possible to filter them out at "View_Elements in 3D view " option
I would like to show wall endings separate from walls.
Anyone has an idea how to achieve it?
1 Solution
David Lukacs
Hi Ananas,
Wall ends are hosted elements, you can't hide them separately. Unfortunately neither can be filtered out in 3D. You can use pillars with complex profiles instead.
David
Go to post
1 Reply 1
David Lukacs
Hi Ananas,
David
