2011-09-25
11:52 PM
2023-05-24
01:04 PM
Rubia Torres
2011-09-26 12:02 AM
2011-09-26 12:10 AM
2011-09-26 12:48 AM
2011-09-26 01:10 AM
2011-09-26 02:52 AM
Catalin wrote:What I suggested is not a copy of the slab but to fill the hole with a slab and set the filler to be demolished.
And for the slab isn't a solution to make a copy of it and one as existing and one as new with the hole on it... on the demolition plan will appear as you demolish the whole slab instead of a hole and make the renovation feature useless.
2011-09-27 06:02 PM
2011-09-27 08:50 PM
2015-12-07 05:16 PM
Matthew wrote:The problem is, that if youCatalin wrote:What I suggested is not a copy of the slab but to fill the hole with a slab and set the filler to be demolished.
I am inclined to agree that the renovation feature could do with improvement but I haven't actually used it yet. Only looked it over a bit. With the kind of work I do I probably won't have much use for it unless is expanded to provide for more complex phasing.
2016-10-07 02:30 PM
