how can i make this complex shape and give it 2d symbol ?
HI, just wondering how i can make like this inside archicad 15
22 REPLIES 22
Steve Jepson
I could model that in ArchiCAD. I could also build a house with just my hatchet and a string. It's just not very productive.
In this case, the forms have not been refined into manufacturalble and constructible parts yet. It's still quite free-form. From my perspective, there is no such thing as a free-form building, unless its a mud hut or something which does not need plans anyway.
I think ArchiCAD is for doing just the opposite of free-form. ArchiCAD is for producing the documentation/plans necessary to transforming this sort of free-form shape into something buildable that can be constructed with precision. I could do that with ArchiCAD. I could produce a good set of working drawings to be used for constructing a building of that specific shape. If you want to pay me for my time I will do it....with ArchiCAD.
pixpast wrote:
when archicad can produce this clearly and without too much sweet, is the day i say, archicad has beaten revit.
Ian
"Tonight's the Nigh..." like Dexter says.
Only with archicad, no plugins (no archiforma, no objective, no mesh generator... pure archicad this time about five minutes...
Jose You are amazing go for best you made me breath to start like archicad again.
I hope you do not forget me on some nice tutorial of course when you empty
wish you the best
My best regard,
Steve Jepson
That isn't even close.
Jose wrote:
Ian
@Jose: in 5 minutes for this ? it's look amazing! How can you do that? a curtain wall with custom panels ?
Hi all,
I' looking for the way to model something like that. I had to model a number of "Pipes" run in many directions. Finally i did it with Cadimage tool, but is there any way to create a real space framing around the pipes rather than use texture materials?
any advice is appreciated !
Riiiiv wrote:
Jose wrote:
Ian
Hi all,
Yes, this time I make two custom panel for curtain wall, and then one curtain wall, in esquema you can choose the pattern... That's all.
i tried to do it using custom panel fine but i can not produce shell shaped by curtain wall please joze tell us how
Videotutorial Archicad
I upload the videotutorial (about 8 minutes), in "noticias"
I will edited and upload in hd in this days.
Jose.
Joze ,i can not see the tutorial , i see only your presentation.
Better resolution!!!
Videotutorial complex facade with Archicad 15 (no plugins):
Tutorial Archicad
