2013-12-15 01:40 AM - last edited on 2023-05-23 02:33 PM by Rubia Torres
2013-12-15 02:06 AM
2013-12-21 11:48 PM
2013-12-22 12:14 AM
2013-12-22 12:16 AM
2013-12-22 02:17 PM
ROBERT wrote:If the Connect command is too broad, then kill the Connect and SEO the Walls and the Roof.
I got to the Design; Connect Tool and was able to get the roof to extend under the upper roof by Clearing all connections which then changed clipped walls under the lower wall. The trimming issue will work only one way.
2013-12-22 08:04 PM
2013-12-22 10:22 PM
ROBERT wrote:You haven't provided enough information to suggest that this is an AC/Graphisoft problem vs one of not using the tools the way they were designed to be used. There haven't been many posts from folks having problems, so it is hard to tell if you've come across a unique situation that needs to be addressed or not.
Graphics oft needs to correct this problem internally.
2013-12-22 10:54 PM
2013-12-23 01:35 AM
