2011-09-0304:24 AM - last edited on 2023-05-2612:30 PM by Rubia Torres
2011-09-0304:24 AM
Hi i have question i tried to hide projection of beam over a wall by trying to do changes in setting ,beam priority but i still can not hide the lines of beam what can i do to hide the beams projection over floor plan display and thanks
Select the beam and use the command Display Order > Send to Back, or select the wall and use the command Display Order > Bring to Front. If you are not familiar with these commands, search them in the Help files.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
