how i make the grid element tool being exactly at middle ?
Hello there i need a quick way to make grid lines axes to snap to the middle of the wall or to be in the middle of the wall while i am putting grid axes
and thanks
1 REPLY 1
When you placed the walls, you can select the construction method to be by (Right, center or left edge) if you change the walls to center, you will be able to move the grid line and snap it to the center of the wall.
if you have the grid line in place and want a wall centered in it, just select CENTER as the construction method before starting to draw the wall.
Hope this helps
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
