how to create chamfer box ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-07-12 01:50 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-12 02:19 PM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-12 02:23 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-12 03:26 PM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-12 04:22 PM
Download it from here: http://archilib.od.pagesperso-orange.fr/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-12 08:07 PM
ejrolon wrote:Note that if you make the top and bottom horizontal elements in the custom profile AND set the Horizontal STRETCH to only the horizontal parts, you can adjust the "Width" of the box to meet in the middle...
here you go
Tip: Make those horizontal legs as SHORT as possible... You can only STRETCH longer...
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-12 09:10 PM
When placing walls, a matching corner radius curves the corners.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-12 10:08 PM
It will struggle to make the curved corner... Done it many times with no real good result...
As shown in the Red Graphic, adding a cube in the middle will help the joinery...
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-12 11:50 PM
Unlike your cube, the side edges are right angles. ArchiForma itself does not have a parameter to chamfer them - they would have to be manually filleted in the extruded form.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-12 11:55 PM
Note again that the top and bottom fillet of 6" is parametric. The extruded corner fillet was done manually via the pet palette to all corners of the fill prior to having ArchiForma extrude it. So, if the fillet amount changes, the shape would have to be re-created.
Note also that you can see the polygons in this OpenGL capture. If you are using an external rendering package such as Artlantis, these facets will be smoothed out.
