how to cut 3d model?
hello. i've start working on archicad this week, and was able to make an apartment only i dont know how to look at it from the inside?
i want to print the look from inside the apertment, and also how do i creat the floor to look like ceramic? or a carpet?
thank you very much in advance for your help, i have a projet due to this week.
6 Replies 6
Do you want a perspective view from the inside, or a 3D cutaway which reveals the inside?
Ralph Wessel BArch
Central Innovation
i would like to make a prespective view from the inside.
please help me. thankyou in advance.
michal.
Use the Camera Tool on the ToolBar. First click places the Camera, second click places the point you are looking at. Selecting the Camera and pressing CTRL-T brings up its Settings Dialog where you can adjust those settings. Select the Camera, go to Image\3D Projection Settings. Your Camera settings will be applied to these settings automatically. OK the Dialog, then press CTRL-3 to view it in 3D.
You can find extensive documentation on ArchiCAD functions in the Manual and Help file.
Djordje
PLace a camera. Right click on it, choose 3D window. Use the 3D window palette (will show up below the 3D window when you open it) to change your view point.
Enjoy
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
YOU SEEM TO HAVE THE CAMERA PORTION TAKEN CARE OF PRETTY WELL. SO I WILL TRY TO HELP WITH THE MATERIALS. FIRST YOU NEED TO CHOOSE YOUR SLAB OR FLOOR COVERING WHICHEVER YOUR CHOSE TO USE. CLICK THE "SETTINGS DIALOGUE BOX" AND GO TO MODEL. CHOOSE YOUR MATERIALS THERE. IF HOWEVER YOU CHOOSE A MATERIAL AND IT DOES NOT SHOW UP. GO TO MATERIALS IN THE OPTIONS PULL DOWN MENU. THERE YOU WILL HAVE TO APPLY A TEXTURE TO THE DESIRED MATERIAL WITH THE EDIT TEXTURE OPTION. HOPE THAT HELPS. I UNDERSTAND ABOUT THE DUE PROJECTS. I HAVE A REMODEL I NEED TO COMPLETE THE CD'S FOR AND A MODEL RENDERING IN SKETCH MODE I HAVE TO HAVE BY TOMORROW MORNING. GOOD LUCK.
Djordje
Rule No 1 of Internet correspondence:
Thou shalt not shout. All caps means shouting.
This is a cool place ...
Djordje
HP Omen
