‎2011-01-13
06:20 PM
‎2023-05-26
02:33 PM
Rubia Torres
‎2011-01-14 08:27 AM
‎2011-01-14 11:56 AM
‎2011-01-14 01:38 PM
‎2011-01-14 03:27 PM
kielbasa wrote:I'm a bit confused. It sounds now like you want a cube that isn't square in plan has an irregular top and sloping walls - so not a cube aside from being polygonal.
Mates, yes but in this case using mesh tool none of vertical walls of our solid is slanted (corners are one over another).
Using slab is pretty much the same (maybe I omit sthg). I can move corners, but again, each of bottom corner is exactly below the above one.
Cube 12 would have been good and I can rotate it in space, but here all walls are same height.
‎2011-01-14 03:53 PM
‎2011-01-14 06:54 PM
‎2011-01-14 07:10 PM
‎2011-01-14 10:29 PM
kielbasa wrote:May be this old part can do the trick.
Guys,
Let's say that I build a cube.
I switch to 3d window, and I would like to manipulate each corner, so that I would be able to change its height (x,y axis as well so that when I come back to floor plan it wouldn't be a square).
How should I do it? I'm using arch12.
I tried to find such element in the library , so that each corner would be editable, but seems there's no such thing there.
thanks.
‎2011-01-15 12:30 AM
