how to edit object?
I need to make changes to the object fI've created for example, fill,materials, pen, etc. How do i do that?
3 Replies 3
If you had created the objects by programming in GDL, then I assume you would know the answer. So... I assume that you saved your objects from the plan or 3D window? The changes WILL require some very basic GDL, but it is pretty simple stuff.
Since you aren't on 9 yet, you can read the documentation over the web at:
http://download.graphisoft.com/ftp/publishing/ac9_help/wwhelp/wwhimpl/js/html/wwhelp.htm
Click on the book "Introduction to Object Making" and start reading... Chapter 7 is probably what you're looking for.
Karl
thanks karl.
i'm slowly getting there. i just open the libary part of the object and seeing a list of stuff there that i can add into the library part. i am tyring to add the background fill because my object is 'transparent' on 2d plan....
lsid wrote:
thanks karl.
Aha. Yes, this is something different - I thought you wanted to parameterize existing elements. I'll answer in the thread where you post your example:
http://archicad-talk.graphisoft.com/viewtopic.php?p=23597#23597
Karl
