Lingwisyer
Guru
Teamwork Reservation Overrides
Hi all,
Is there some way to edit this? I would like it to only override things reserved by others, and I guess requested items. I do not want it to override unreserved items.
Ling.
3 Replies 3
I don't have Teamwork on my computer right now, but you can try this:
Go to the Graphic Override Rules Dialog in your Teamwork Project, click the "Add" button in the Criteria panel, and see if there are any such Teamwork-specific criteria available (like Reservation Status or Reserved By). If there are, then you can use that in the Graphic Override Rule.
Lingwisyer
Guru
I was talking about the Reserveration Overrides rather than the Graphic Overrides as if you use GOs to show reservation things, then you cannot use it for anything else... I am basically looking for a Show Reserverations by OTHER Users.
Noemi Balogh
What you're talking about it the Colored Workspace (https://help.graphisoft.com/AC/28/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC28_Help%2F080_Colla...)
Since the colours are coming from the Work Environment (https://help.graphisoft.com/AC/28/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC28_Help%2F140_UserI...) , I assume there's no 'transparent' colour for free to reserve items and the reservations by you are handled within your BIMcloud user profile (which again, doesn't have transparent option). However, you might select a different colour than blue, which might be less bothering.
Alternatively you can try 'Grey out unowned Workspace', but I guess you'd like to see what is reserved by whom, so it's really just a partial solution either...
Noémi Balogh
Staff Community Expert, Admin
