how to rotate in 3d a steel beam?
I WANT TO ROTATE IN YZ OR XZ AXIS A STEEL BEAM BUT I CAN'T!
ARCHICAD GIVES ME THE OPTION TO ROTATE IT IN XY ONLY AND NOT IN 3D. IS THERE A WAY TO DO IT?
cigraph have a free download available that does this:
http://www.cigraph.it/cigraph/pagetrans.do?action=current_product&prodotti_id=26&lang=en
you don't show which version of archicad or platform you're using - you may have to search for the correct one.
Take a look at OBJECTiVE. In addition to a tool for 3D rotation, you can freely cut the steel beams in 3D. It is bundled with a steel library that is more 3D aware, and can also be bent to curves in 3D.
Ralph Wessel BArch
Central Innovation
Maybe the beam tool could help you (using, of course, the inclined type and a custom profile for its cross section).
Cheers.
Adrian Tudoreanu
