‎2006-03-04 05:13 AM
‎2006-03-04 01:30 PM
‎2006-03-05 06:03 AM
‎2006-03-05 07:45 AM
‎2006-03-05 08:58 AM
‎2006-03-06 04:05 AM
ishpalsingh wrote:Do it in 3D window.
i wanted to use drag a copy but it gets greyed out in a section do u know other ways to make copies in section
ishpalsingh wrote:If you are using the cylinder from the Basic shapes folder, it has a rotation parameter. Input the roof angle.
i have a roof at a slope i want to align these cylinderical beams with the roof.how can i do that?
ishpalsingh wrote:Where? Plan, elevation, section?
also i have added a structural grid in plan which has columns tags already attached to the columns.I wanted to add a tag to the ridge how can i do that?
‎2006-03-07 06:11 PM
Djordje wrote:all the grid objects get selected together how can i copy one of them
You can add it when defining the structural grid, or simply copy one of the placed grid objects where needed and change its marker to whatever you need.
Can you post a screenshot so we all know EXACTLY what are we talking about?
‎2006-03-08 04:06 AM
ishpalsingh wrote:Select them in the plan, copy, paste to S/E. You will have to rotate and/or mirror it to the position. Hint: use the origin as the reference point
i would like them to appear in section and elevation view
ishpalsingh wrote:They are grouped; suspend grouping, and you can edit individual objects.
‎2006-03-08 04:13 AM
‎2006-03-08 04:18 AM
ishpalsingh wrote:Well, you can't. As you can't learn anything else in life without one.
i thought i can never learn archicad without a teacher
ishpalsingh wrote:I am honoured; however, try to look arond you, and find someone who is physically nearer. It will help you, no end.
i hope i have found one in you
