Streamline your workflows and master BIM coordination! Program starts April 28.!
how to scale fill types
i am using archicad & i am newly convert from autocad to archicad
i have tried to change the spacing but nothing happens
10 REPLIES 10
Aussie John
Hi welcome to the light side!
You might have the fills set to be viewed in bitmap. Check your display settings. You need vectorial hatching
Cheers John
[/size]
thanx for replying
one thing more i am using cylinder(object-basic shapes) as a beam
i wanted to use drag a copy but it gets greyed out in a section
do u know other ways to make copies in section
i have a roof at a slope i want to align these cylinderical beams with the roof.how can i do that?
also i have added a structural grid in plan which has columns tags already attached to the columns.I wanted to add a tag to the ridge how can i do that?
plz help
Aussie John
you cant make copies in section view- do it in the plan then align. As to the last query I dont know
Cheers John
[/size]
is there any way to add tag?
Djordje
ishpalsingh wrote:
i wanted to use drag a copy but it gets greyed out in a section do u know other ways to make copies in section
Do it in 3D window.
If you are using the cylinder from the Basic shapes folder, it has a rotation parameter. Input the roof angle.
Where? Plan, elevation, section?
You can add it when defining the structural grid, or simply copy one of the placed grid objects where needed and change its marker to whatever you need.
Can you post a screenshot so we all know EXACTLY what are we talking about?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
thanx Djordje
for helping
i had a structural grid which has tags in plan view
in between the structural grid lies the ridge i want a tag for the ridge
i would like them to appear in section and elevation view
all the grid objects get selected together how can i copy one of them
Djordje
Select them in the plan, copy, paste to S/E. You will have to rotate and/or mirror it to the position. Hint: use the origin as the reference point
They are grouped; suspend grouping, and you can edit individual objects.
HTH,
Djordje
HP Omen
thanx thanx very much
now i can start working at archicad again
i thought i can never learn archicad without a teacher
i hope i have found one in you
Djordje
Well, you can't. As you can't learn anything else in life without one.
The problem is - if there is no one to teach you, you will not be aware of how little you know. The more you learn, the more you will be aware of what you don't know.
I am honoured; however, try to look arond you, and find someone who is physically nearer. It will help you, no end.
Djordje
HP Omen
