2004-08-15 06:11 AM
2007-02-02 04:41 PM
2007-02-02 08:55 PM
2007-02-03 12:03 AM
2007-02-05 01:25 PM
laszlonagy wrote:They do & they don't
Sections/Elevations use the 3D Window settings....If you save a Section View, the 3D Window settings (including Transparency) will be saved with the View...
2007-02-08 05:41 PM
2007-02-09 01:33 AM
2007-02-09 01:39 AM
laszlonagy wrote:Me too. Well, it is related to views, it's just that there's a bug which currently prevents their redefining to include transparency.
Of course.
I thought you knew that.
2007-02-09 11:22 AM
Just as the Transparency in Shading field of the 3D Windows Settings Dialog controls transparency in Section/Elevation Views, so it is the one taken into account when saving Views.It’s not taken into account when saving Section Views.
2007-02-12 02:56 PM
Akos wrote:I looked at this thing again and it seems like that after you place a Drawing on a Layout the source of which is a Viewpoint or a View, you can change the Transparency in Shading to OFF, and the Drawing will correctly update, but then as soon as you did this, there is no way that you switch it to ON and the Drawing update correctly.
Me too.
I knew that the transparency in sections is controlled with ‘Transparency in Shading’ field of 3D Window Settings. What I didn’t know is that it’s in no way saved with Section View as it turned out.Just as the Transparency in Shading field of the 3D Windows Settings Dialog controls transparency in Section/Elevation Views, so it is the one taken into account when saving Views.It’s not taken into account when saving Section Views.
You can turn on and off transparency for the Section View after you have placed it on the layout without even opening it. That’s what I was trying to say.
2007-02-12 03:00 PM
