how to turn off/on opening lines for windows and doors?
can please someone tell me where can i do this? because i dont want that lines are visable in 3D document.
Thanks!
5 Replies 5
NCornia
princ,
Document>Set Model View>Model View Options
Under the Options for GDL Objects header you can uncheck the boxes to show the opening lines.
This method is global and will remove all door or window opening lines.
If you have ArchiCAD 14 you can turn the opening lines off for individual doors/windows in the object's settings.
Here is a link to a previous post on this topic: http://archicad-talk.graphisoft.com/viewtopic.php?t=33869
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
INTEXHOMES
What if I need to turn off the opening line from one of the door leaf?
Disable the opening lines in the door settings as shown here.  Note that this permanently eliminates the opening lines in all views:
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
INTEXHOMES
If I have a double garden door. I need to show that one side opens and another side is not. If I disable opening lines, it disables it for both leaves. I need to keep it for one leaf and disable it for the other leaf.
Screen Shot 2022-10-05 at 11.28.10.pngScreen Shot 2022-10-05 at 11.27.49.png
Unless there is an option in the object to make one of the leafs fixed (I doubt there will be - the idea of a double door object is that it will have 2 opening doors), you will have to resort to white lines to cover the door swing lines.
Or turn them all off and draw in the ones you want.
