i want to make Reinforced Concrete on beam
Hello i want just in the attach to make reinforces concrete continuing with the reinforced concrete below slab can anyone tell me the method
11 REPLIES 11
i want to know how to make detailed section in archicad like autocad can anyone tell me (all i know is composite fill but how to apply i do not kno
David Maudlin
ahmed_hassan:
Use the Beam Tool, set the Cut Fill to match the concrete in your slab, and set the top of the beam to the same height as the bottom of the slab, the fills should merge in section.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hello ahmed_hassan,
you have to control two aspects:
1. the cut fills of the different elements.
2. the Model display tab in the settings of the section.
I hope it helps.
best regards
frankly i do not understand because i really face problem of how to make reinforced concret go penetrate the wall in section and how slab can be done without interruption of reinforced concrete as its own shape and for David i do not know how to merge
Thanks for David Maudlin , David Maudlin for trying to help i am appreciating it.
waiting others if they can help more
It's easy. Just see the pict.
You adjust here. (see pict)
yeah i am seeing and following please continue if there is rest you can add it
I guess that is all. 🙂
For the effect you want. It works with all kinds of materials in sections.
You just have to get the hang of it.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Ahmed,
If you are wondering how to place the objects:
Place the beam in the wall at the same height as the slab. Stretch the vertical height of the wall down to the base of the beam.
As has been mentioned above, if the cut fills of your slab and beam are the same you will achieve your desired section.
Note: my example below is in English/Imperial units.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
