Tom Krowka
import/xport display options.
Is there any way to import/export display options from one pln to another?
I'm trying to put together a template from various bits and pieces of various .pln's.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
4 Replies 4
Ben Odonnell
Tom,
You could try merging the PLN file with the right Display Options into the template file.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
At the end of this article about Display Option Combinations at
http://www.graphisoft.com/support/archicad/archiguide/diplayoptcomb.html
there are some tips on this.
It is not possible to do this but you can make your future Project use the Display Options Combinations you defined.
Aladar Kish
Thanks a lot (Köszönöm szépen) Laszlo,
Great article!
It took me awhile but I got it.
AC 4.2 - AC 24 7006 FRA
mac OS 11.6.7
You are welcome.
