inclined slabs
Hi, I'm a new user and I'm having a hard time adapting, I've been using AutoCad for more than 8 years and it's not an easy change!
I'd like to know how can I rotate/incline a slab. Theres an option for this if you're building a wall, but I can't find anything relating to slabs.
Also I'd like to know if anyone knows about a gdl pivoting door, I really need it!
Thanks in advance
If you want to create an inclined Slab, maybe the Roof tool is what you should use for that.
OK, thanks, I'll give it a try. I thougth there was a simpler way to do it. I'll let you know how it worked.
