‎2016-01-04
03:31 PM
‎2023-05-24
12:42 PM
Rubia Torres
‎2016-01-05 08:38 PM
leceta wrote:
Hi all!
Need your help!
I am having an issue with PBC. Please, see attached image
I´am creating a composite.
Initially, the intersection between two walls with the newly created composite behaves as expected. But when i add a new external finish to the composites, an annoying and incorrect line apperas in the intersection.
Building material priorities are checked, and they are ok.
Neither nothing strange with layer intersection ID (by the way, both walls are in the same layer)
May be a bug?
thanks!!
aitor
‎2016-01-06 03:35 AM
vgodzb wrote:If this doesn't work (can't test at the moment) then try playing around with the strength of the external skin building material.
Change the finish material Type to a finish material.
‎2016-01-06 11:46 AM
There was a post a little while back (I am sure it was in this forum but I can't find it) about a bug when the BM strength was below a certain figure (around 450 I think). This caused problems with the automatic trimming.It could be this the post ? :
I wish I could find the post - I know I replied to it.
I am sure it was very recent and have checked all my posts in the last 2 months but can't see it.
If I get time later I might experiment.
‎2016-01-06 09:17 PM
There was a post a little while back (I am sure it was in this forum but I can't find it) about a bug when the BM strength was below a certain figure (around 450 I think). This caused problems with the automatic trimming.exactly this is the problem. I was using Building Material with a priority higer than 545. This is exactly when the problem starts. With 546 it doesnt work.
‎2016-01-07 03:48 AM
Fra wrote:Yes that is the one.
http://archicad-talk.graphisoft.com/viewtopic.php?t=51191&start=0
‎2016-02-25 02:42 PM
