2003-11-02 07:45 PM - last edited on 2023-05-26 12:55 PM by Rubia Torres
2003-11-02 08:29 PM
Jefferson wrote:You sure they're 10 x 10 square columns, and you haven't accidentally hit the circular column option? Circular columns tend to give problems because they don't have vertical 'edges'.
Here's a good one---
I have covered porch with 10x10 columns, outline pens for plan, section and 3d set to the same heavy black.
2003-11-02 09:38 PM
2003-11-02 09:41 PM
2003-11-02 11:01 PM
2003-11-02 11:22 PM
2003-11-02 11:25 PM
Jefferson wrote:Yes. Very strange. It seems to me to have something to do with the shadows - how does it generate when the shadows are turned off? Any improvement?
I"ll give it a try posting both the info box and a cropped elevation with some columns selected. You'll see that the selection dots indicate the way the columns are being "seen". Note the lack of outline pen on the "inside" columns. They all have the same settings, verified and reverified.
2003-11-03 01:30 AM
2003-11-03 05:52 AM
2003-11-03 05:59 AM
Jefferson wrote:This most often happens because of the duplicates, and also - check your wall/column wrapping. That can often be a culprit.
The shadows were a non factor. David's call on the wall, I'm thinking, is the governing factor. But how and why?
