We value your input!
invisble solid fill
Kristen
I have walls which I would like to draw with a solid fill in plan but all I get is 2 lines and an empty fill for my walls. I have the same problem in section with a slab and mesh which do not appear as solid.
There are so many places to enter setting for fills and displays now (in AC10) so I do not know where the fault lies. I have checked all I know of and still can't get a solid fill.
How irritating to get stuck on something as seemingly simple as this!
Anyone know what I have done wrong?
Kristen Broberg
AC 23 SWE Full on Windows 10 Pro
HP Zbook 15 G6 32GB
i7-9850H 2,6GHz
Quadro M2200 2GB
www.liljewall.se
Rod Jurich
Kristen, you haven't done anything wrong. It is GS in deciding to hide things that were familiar.
Go to Documents/Set model View/Model View Options.
I think you will find there is where you will change settings that will enable what you want.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Kristen
Thanks Rod!
Figured it out with a combination of that and display options in wall settings.
cheers, Kristen
Kristen Broberg
HP Zbook 15 G6 32GB
i7-9850H 2,6GHz
Quadro M2200 2GB
www.liljewall.se
