line ends and corners
Dave Brach
how do you change the end of a line, or the corner of a polyline, or the corner of the frame of a fill outline to be crisp/90 degrees instead of rounded?
Dave Brach/architect AC28 Macbook M4 Pro OS Sequoia
6 REPLIES 6
Eduardo Rolon
You can't.
AC does not have that option.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
RandyC
It is available in Archicad 21
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Eduardo Rolon
I am using 21 and I don't see that option for end caps like in Illustrator, what is new in 21 for dash lines and objects is that there will always be a line in a corner
AC29 US/INT -> AC08
another Moderator
Bill
I'm in 23 and my polylines don't always have something at the corner... is this only for lines?
Bill Szustak RA
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
Eduardo Rolon
It should be there in 23 (don't have it installed) and it should apply to PL.
AC29 US/INT -> AC08
another Moderator
Bill
Thanks!
Bill Szustak RA
