line thickness setting
Hello
I want to set line with various thin or thickness, how can it be done?
Thanks
Eduardo Rolon
This is a basic question so you should check the manual, help and example files.
The answer is that Line Weight is controlled by the Pen Settings (which you should configure to your liking) and you choose them in the pen icon which has "62" in your screenshot.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
AC28 US/INT -> AC08
another Moderator
OK show true line weight then pen /color setting
Thanks Ejrolon
