2024 Technology Preview Program
making story instance
niniiiii
hi, i am making 15 story high building and because of that i want to make stories instance. when i change something on one story i want it to also change in others. how can i do that ?
Marc H
Hi niniiiii,
You can create one or more hotlink modules and link them as needed into each floor. They will update when you change the modules.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Marc H
Hi niniiiii,
okay thank you so much, i will try that
