Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
mansard roof
hi
i would like draw mansard roof . building has got shape quadrangle shapeless so wall has got changeable high. how do it?
4 REPLIES 4
j0asia wrote:
hi
Could you post a sketch?
The PolyRoof construction method of the Roof Tool may be what you are looking for.
Check the Manual for its description.
Djordje
Try
http://www.graphisoft.com/archiguide_archive/ArchiGuide_Online_6o/issue15/roofs.html
In general: do two single plane roofs, make the gable walls as high as the roof ridge, trim the walls to roofs. That's it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
this is sketch
