Display malfunction of Graphisoft ID dashboard
Learn more
menu bar problems
went back to work on a version 16 project in teamwork, don't have design in my menu bar so i cannot do solid object operations. how do i get it back in my menu?
David Maudlin
Gary:
Open Work Environment > Command Layout Schemes, then select and apply the Standard Commands 16. This will rest the Menus and Toolbars to the standard setup. Or you can add the SEO command to the current menu scheme.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
