merging or combining plines that are overlapped or end-end
rob2218
is there a way of merging or combining plines that have overlapped or are simply two plines end to end?
I know in the other 2D program from Autodesk...there was a "join" function that allowed ends of plines to 'join' and become one pline.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
15 REPLIES 15
rob2218 wrote:
is there a way of merging or combining plines that are simply two plines end to end?
Edit/Reshape/UNIFY is the right command. NOT for overlapped ones.
rob2218
thanks, I'll try that one.....I knew there had to be something...anything by way of making end to end plines merge...
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
ok, I had two plines end to end on different layers and with different pens, didn't do a darn thing.
I selected both plines, clicked on the "Edit>reshape>unify" function and nothing happened.
i>u
Edgewater, FL!
SOFTWARE VERSION:
For me everithing is OK.
I have 3 plines, each of them on different Layer and with different Pens. I select the Blue, then the Green and last the Red polyline, then pick the "UNIFY" icon and it works. Now I have one polyline with Layer and Pen set by the last selected polyline segment.
rob2218
What would be the sequence of the steps?
Select first pline.....then what?
i>u
Edgewater, FL!
SOFTWARE VERSION:
1. Select the plines (with window - from left to right; crossing window - from right to left; one by one;....)
2. Pick the icon "Unify"
3. Done
rob2218
OK, something discovered today. Here's why it wasn't working.
if the pline is "open" ended, meaning the two ends done make a closed looped...then the function UNIFY will work.
If the pline is a closed loop....the function doesn't work, bummer.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
So...what i was hoping was that I could grab a bunch of plines...say from a manufacturer like a window sill profile and make it into ONE pline...but since the window sill (as an example) is a closed loop...it won't work....again..bummer.
i>u
Edgewater, FL!
SOFTWARE VERSION:
