2023-12-15 05:46 AM
Hi. I'm missing my mesh in 3D but there is in the survay that I'd created before I started drawing. Could you help me how I can mesh back again. Thanks
2023-12-15 06:23 AM
Check the layer is on.
The 3D filter settings does not have mesh visibility turned off.
There is no renovation filter active.
Press the 'fit in window' button in case it is a long way away.
2023-12-15 07:23 AM
If it has not been visible since you first generated your mesh from the survey data, check that your survey data does not include rogue zero nodes or overlapping nodes. The existence of these may cause a mesh to fail to generated due to invalid triangulation.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
