We value your input!
morph projection
alemanda
Hi to all,
I have the following problem with the morph.
I made a morph on story 0
Heighest point of the morph is below the level of story 1.
I set the morps as projected on all the relevant stories.
I set the cut plane level
I can see correctly all the other elements except the morph.
I can see also the morph only if the heighest point of the morph is above the level of story 1.
Is it a bug.
Do I miss something?
Thanks
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
5 REPLIES 5
Try using "Home & One Story Up" instaed. "All Relevant Stories" works only when:
All Relevant Stories: The element will be shown and editable on all stories which it physically intersects.
See here for more detail.
alemanda
There's something strange.
Walls are set visible in all relevant floors and they are shown correctly even though they don't intersect the story.
See the picture above.
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
alemanda
... is it a normal behaviour of AC?
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
So to summarize it to anyone who is not getting deep into this thread:
You have a Morph and a Wall placed on Story 0.
They both have their Show on Stories option set to All Relevant Stories.
The top point of both is below the level of Story 1 so they do not intersect the level of Story 1.
You go to Story 1.
In the Floor Plane Cut Plane Dialog you set the Show Down to field to 1 Story Below. So in Story 1 you want to see elements placed on Story 0 (Story 0 is their Home Story).
The Wall will be visible on Story 1. The Morph will NOT be visible on Story 1 with the above settings.
One would assume that since the Morph is set to All Relevant Stories, and since the Floor Plane Cut Plane Dialog is set to show elements on 1 Story down, the Morph, being on Story 0, should show on Story 1, just as the Wall is shown.
But the Morph does not show.
I am going to report this to Graphisoft. Meanwhile, I think you should be using the solution alexwang32 has given you.
alemanda
Yes Laszlonagy
It is as per your point by point description.
It seems a bug ...
Thanks
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
