‎2005-02-02
09:37 PM
‎2023-05-23
05:23 PM
Rubia Torres
‎2005-02-03 10:28 PM
‎2005-02-04 08:23 AM
Beginner wrote:First: do NOT Open, Merge the DWG in. If you Open, the default ArchiCAD layers will not be present. Take care that the units assumed in AutoCAD are the same as the units defined in ArchiCAD, that the scale in ArchiCAD is the same as the intended scale in AutoCAD.
Today I opened a .DWG file (Acad 2004 creation) which had several iterations of drawings for a small 2 floor house in it - 1st/2nd floor and several different elevation options for each side of the house.
Beginner wrote:Why a new file? Everything is in one file. Organize your design by storeys.
I then opened a new file and pasted the drawing in. To my surprise, all the wall segments and labels have white dots which seem to define the corners of each object plus either a mid-point or center white dot. How do I turn the display of these dots off?
Beginner wrote:You do NOT have any 3D info; you have to build your design from scratch. A very nasty question: did you have ANY training, is there a helpful reseller/experienced user near by? Some initial handholding will help you immensely!
Displaying my ignorance, how can I take this imported drawing for the 1st floor and then also import the 2nd floor and elevation drawings and have everything 'register' correctly so I can then use the 3D, fly-through, and all the other advanced end-user whizzbang viewing tools?
