First off, make sure your "Show on Stories" parameter for each object is set appropriately. For doors and Windows, "Floor Plan Display" should be set to "Symbolic" to display regardless of FPCP. Roofs' "Floor Plan Display" is typically set to "Outlines Only" in order to disregard the FPCP. Walls may require a number of different "recipes" depending on your intent.
