opposite of 'Split'?
i have used the 'Split' command to break up some walls and now i need to 'combine' certain parts again (i.e. make 2 parts into a whole).
i have tried all the Reshape operations but nothing seems to be able to join the walls again - is there a way to do this?
20 REPLIES 20
Unfortunately, not possible.
There is the line consolidation command but that works only for linear elements.
Of course you can trace your Walls with lines, do line consolidation on those lines and then trace those lines with Walls.
But just redrawing those Walls might be faster than this.
thanks for the quick reply. i would have drawn them again but they are in a tricky situation (intersections etc.) so i think i'll just leave them as they are.
thanks anyway.
note - maybe one for the wishlist?
Yes, you can always make a wish.
Wishes many times come true.
It is painful that GS has not provided a wall-merge feature yet.
You can use the magic wand to recreate your walls from the split walls. Then, of course, you have to re-insert your openings. Eyedropper from the old wall, place in the new, and then drag to align. As I said, painful.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Djordje
Did you try Unify?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
rocorona
Did you try Unify?
Good attempt. Unfortunately Unify can only join Lines/Arcs/Polylines to make a single Polyline
(but I had to try it to be sure...)
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Did you try Unify?
Shame on me for not suggesting Unify, but Line Consolidation instead.
Djordje wrote:
Did you try Unify?
that's the first one i tried!
Erich
This is possible to do with the tools we currently have. Select both walls, go the to Model Menu>Select Complex Profiles>Select Merge Walls. While it is perhaps not the most obvious place to look, it does work and your previously split walls will become one.
HTH
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
