2006-09-21 11:37 PM - last edited on 2023-05-26 03:28 PM by Rubia Torres
2006-09-22 12:51 AM
2006-09-22 07:40 AM
NT wrote:Are you sure that this does not happen after you change a view and therefore the pen set associated with it?
Objects that are assigned a to a pen w/ a weight of 0.10 mm will inadvertently and randomly switch to a MASSIVE line weight - probably in the range of 10.00 or more. this will only happen with a few at a time, then i will set the offending objects to a different pen, but this does not always solve the problem.
2006-09-22 07:44 AM
Djordje wrote:. . . if only pensets
2006-09-22 07:46 AM
~/archiben wrote:OK, OK, assigned ...Djordje wrote:. . . if only pensets
Are you sure that this does not happen after you change a view and therefore the pen set associated with it?wereassociated to views, eh?!
ben
2006-09-22 10:04 AM
