pen weight bug
Objects that are assigned a to a pen w/ a weight of 0.10 mm will inadvertently and randomly switch to a MASSIVE line weight - probably in the range of 10.00 or more. this will only happen with a few at a time, then i will set the offending objects to a different pen, but this does not always solve the problem.
I have gone into my pen attributes and changed all 0.10 mm pens to 0.09 but hasn't seemed to help.
Have been having difficulties w/ this for weeks. I have not yet updated to the new hotfix for ac10 (still on 966) because we are too busy at the moment to coordinate all teamwork members to switch at the same time.
is this fixed in the hotfix?
thanks for your help
am on a PC w/ XP pro
5 REPLIES 5
Brad Elliott
Have not seen this happen on the Mac side.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Djordje
Are you sure that this does not happen after you change a view and therefore the pen set associated with it?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
__archiben
. . . if only pensets were associated to views, eh?!
ben
b e n f r o s t
Djordje
ben
OK, OK, assigned ... 😉
Djordje
HP Omen
owen
ah ha!
so i'm not the only one who assumed they would be
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
