2010-04-03
09:19 AM
2023-05-23
02:57 PM
Rubia Torres
2010-04-03 09:59 AM
2010-04-03 12:02 PM
2010-04-03 02:02 PM
creative wrote:Since you have that problem with composites ... as an alternative solution you could use beams with complex profiles. If you only want to have different materials in 3d for top, side, bottom of the roof, simply change the materials in your roofs' properties.
Is there any alternate way to do it?..like we did for walls
2010-04-03 03:41 PM
adytc wrote:i have set different materials in 3d for top, side, bottom of the roof but the overhang is the extended portion so i need 2 paint shades for bottom(internal & external)creative wrote:If you only want to have different materials in 3d for top, side, bottom of the roof, simply change the materials in your roofs' properties.
2010-04-04 09:19 AM
creative wrote:You could split the roof in two,
