plaster for celing
How to add plaster for roof celing?
thanks
5 REPLIES 5
do it with composit slab !
You can make your slab with composite structures !
just assign your composits to work with slabs !
or if you draw roof assign to work with roof
check pic !
My composite structure window is not working(discussed in my thread add plaster for walls).
Is there any alternate way to do it?..like we did for walls
or Atleast is there any method i can show different paint shades for internal & external roof celing (overhang)? just for the 3d view.
Since you have that problem with composites ... as an alternative solution you could use beams with complex profiles. If you only want to have different materials in 3d for top, side, bottom of the roof, simply change the materials in your roofs' properties.
i have set different materials in 3d for top, side, bottom of the roof but the overhang is the extended portion so i need 2 paint shades for bottom(internal & external)
You could split the roof in two,
or: you could add an extra roof under your original roof (for plaster);
or: if you are using beams with complex profiles, you simply insert an extra node on the fill that represents the plaster (in Profile Manager), then select each edge and assign its own material.
