pls open and save
hello, pls i need quick help with opening pmk and lay files created with archicad 6.5. now i;m using archicad 11 and simply i can't open my old project, diaster. pls colud anyone open and save it so i'm able to open it?
thx so much
cheers
tomas
4 REPLIES 4
Eduardo Rolon
Under Help look for the Getting Started Guide for the Migration Guidelines.
You might need this also;
http://www.graphisoft.com/support/archicad/downloads/Fileconverter.html
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
thx, but i simply can't download huge file. it's possible pls for you to open it and save it as AC11 will open it?
Eduardo Rolon
Here you go. This can be placed in an AC11 file using the external content -> place external drawing command
Where do I send the bill
AC29 US/INT -> AC08
another Moderator
Cheers mate
