problem at wall corner
When I draw wall enclosure:
(1) whilst when draw wall enclosure on a blank space, it fillets normally.
(2) but when draw based on the basement trace reference plan, the wall corner cannot be filleted sharply,
Please advice why, see picture above
Also, when I draw an internal wall which attached to the external wall, an unwanted extension part appears, please advice why, see picture below
Thanks
1 Solution
Guru
Suspend groups (alt + g), select two of the walls and intersect (ctrl + i)
Ling.
Go to post
8 Replies 8
There is something in your model which prevents the correct connection between the two walls: a column on a hidden layer, another wall on a higher level (plumb), or a slab or a ground mesh with too high a material priority.
I do not understand this message 😕 but I think it is a material priority subject.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
That means: (1) is the footing at storey of "foundation" , drawn based on the trace reference of "ground floor". Then the wall corner fillet not completed.
(2) is the footing but drawn NOT on the trace reference storey, which wall corner is filleted perfectly
---- this different fillet result could be the effect by trace reference ?
Guru
Does it fillet properly if you manually adjust the reference lines so that they meet each other? ctrl + i.
Tried but seems no way to adjust manually...
and what is the reason why unable to fillet completely automatically
Guru
Ling.
done, thanks Ling,
if possible I want to know the reason why cannot fillet automatically....
Thanks
emailcopy wrote:
done, thanks Ling,
Thanks
The second wall you draw will automatically snap and trim to the first wall, but it will not adjust the length of the first wall.
Guru
When drawing a continuous wall, it might be a good idea to change your building method to chained or in you current case rectangular. Less opportunity to miss align your connections then.
