2020-11-15
03:03 PM
2023-05-09
03:48 PM
Rubia Torres
Solved! Go to Solution.
2020-11-16 04:03 AM
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2020-11-15 05:58 PM
emailcopy wrote:There is something in your model which prevents the correct connection between the two walls: a column on a hidden layer, another wall on a higher level (plumb), or a slab or a ground mesh with too high a material priority.
whilst when draw wall enclosure on a blank space, it fillets normally.
emailcopy wrote:I do not understand this message 😕 but I think it is a material priority subject.
(2) but when draw based on the basement trace reference plan, the wall corner cannot be filleted sharply,
Please advice why, see picture above
2020-11-16 02:51 AM
Christophe wrote:That means: (1) is the footing at storey of "foundation" , drawn based on the trace reference of "ground floor". Then the wall corner fillet not completed.
2020-11-16 02:55 AM
2020-11-16 03:16 AM
2020-11-16 04:03 AM
2020-11-16 05:31 AM
2020-11-16 07:29 AM
emailcopy wrote:
done, thanks Ling,
if possible I want to know the reason why cannot fillet automatically....
Thanks
2020-11-16 07:53 AM
