problem: columns don't link to stories
aryastark
hello archicad folks,
i set the columns home from ground right to the 3. story.
but they suddenly drank red-bull. because they are flying now.
why they are too high? and why aren't they tied to stories?
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
aryastark
found the solution!
edit: solution is setting it to "0".
Ver: AC23
Memory: 16384MB RAM
aryastark
found the solution!
Ver: AC23
Memory: 16384MB RAM
Marc H
Though AC allows multi-story columns, you may want to consider a habit of setting columns with a single story in height (unless they are in open atrium space). This is generally a truer way to depict them (as they often tend to dimension smaller as they go up; sometimes changing profile). It also allows you greater flexibility with the design as well if you need to place or stop them at a particular floor.
There are ways to do this quickly. One method is to set up your grid with the grid tool and place generic columns at the intersections. For additional stories, you can use the Find & Select tool (or simple selection with mouse) and Copy/Paste them on other floors. If the copy group is linked to the next story, AC will automatically link the paste group relative to the next story.
ā€œThe best thing about the future is that it comes one day at a time.ā€ - Abraham Lincoln
AC27 USA on 16ā€ 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
aryastark
thanks for advices, looking forward to implement.
Ver: AC23
Memory: 16384MB RAM
