ā2020-08-25
12:16 AM
ā2025-07-22
12:27 PM
Aruzhan Ilaikova
Solved! Go to Solution.
ā2020-08-28 01:09 AM
ā2020-08-25 09:25 AM
Project2 3,270,2
ā2020-08-25 11:24 AM
ā2020-08-26 08:59 PM
Christophe wrote:valar morghulis Christophe Fortineau,
Hello aryastark,
Did you add this script into your object 2D script after deleting the script automatically generated by Archicad ?
Project2 3,270,2
ā2020-08-26 09:05 PM
Lingwisyer wrote:trying to do waffle slab with "precast double tee" object. but after placement it must be split with line and spline. due to being an object, it doesnot split flexibly, even cutting is not allowed at all.
As far as I know, in a Morph, you cannot. There is no control of 2D Linetypes as you just see a Projection or Cut of the said Morph. There is no Symbolic representation.
For what reason are you needing to explode the object to a morph?
Ling.
ā2020-08-27 11:44 AM
... what it that for?I guess I did not really understand your aim.
ā2020-08-27 03:15 PM
Christophe wrote:thanks, but...
To do a "precast double tee" you should try to do beams with your own profil.
ā2020-08-27 04:01 PM
ā2020-08-27 09:45 PM
DGSketcher wrote:thanks, i can't understand how can we create waffle slab with complex profile beams.
I think your answer lies with a slab and form the waffle grid with complex profile beams. If you use the same material they should all merge. The next bit to fix this is to look at your Model View Options (MVO) where you can control the appearance of the beams below the slab. You can also hide the blue axis line highlighted in your image in the MVO settings.
