problem with zones and complex profiles in ArchiCAD15
We are having problems with zones not working correctly with complex profile walls and I was was wondering if anyone else is having similar issues. The problem is that when a complex profile wall with doors placed in it is used to enclose a space and then a zone is placed or updated in the enclosed space the zone does not see a closed polygon and it bleeds out the doors. Also the doors do not read the zone unless the partial structure display is set to entire model, and the doors have strange relationships to the wall. Doors do not seem to respond correctly to the opening reference lines set in the complex profile. Note, I have checked to make sure all items are on the same renovation setting. See attached screen shots of the warning I get & results I get
0 REPLIES 0
