ā2004-01-31
08:26 PM
ā2023-05-25
06:23 PM
Rubia Torres
Solved! Go to Solution.
ā2004-01-31 08:37 PM
ā2004-01-31 08:30 PM
titioo wrote:Titioo,
Is there a way to find out
in which version of Archicad
the .pln fila is made.
I have a problem opening a .pln file
i known to be ok.
ā2004-01-31 08:57 PM
titioo wrote:The short answer is -Yes, however you might and probably will have problems with the old libraries, depending on which ones you have used.
I don`t see such an option on pc.
maybe a better question is:
can i open in archicad8.1
a file made in any previous version
without problems with the libraries?
10x
ā2004-02-01 08:21 AM
titioo wrote:Right click on the file name in Windows Explorer, select PRoperties - tells you the build of ArchiCAD the PLN was made by, let alone the version.
Is there a way to find out in which version of Archicad
